Salta al contenuto principale
Samsung Galaxy S7 Active Disassembly
Cosa ti serve
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: passo 1, immagine 1 di 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: passo 2, immagine 1 di 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: passo 3, immagine 1 di 2 Samsung Galaxy S7 Active Disassembly: passo 3, immagine 2 di 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: passo 4, immagine 1 di 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro di Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Membri
15 Guide realizzate
Un commento
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,325
