Salta al contenuto principale
Samsung Galaxy S6 Edge Plus Factory Reset
  1. Samsung Galaxy S6 Edge Plus Factory Reset, Grab Your Phone: passo 1, immagine 1 di 1
    • 'Open Settings and scroll down to the Backup and reset option. Toward the bottom of the screen, tap Factory Data Reset.
  2. Samsung Galaxy S6 Edge Plus Factory Reset, Reset Device: passo 2, immagine 1 di 1
    • The on-screen prompts will warn you that all data will be lost and your phone will return to its default settings. Confirm that you wish to perform the reset, and then press Reset Device.
  3. Samsung Galaxy S6 Edge Plus Factory Reset, Be Ready To Lose Everything: passo 3, immagine 1 di 1
    • There will be one final warning. Tap Delete All to proceed. Your phone will now be restored to its factory settings.
  4. Samsung Galaxy S6 Edge Plus Factory Reset: passo 4, immagine 1 di 1
    • Turn off your device Hold the volume up, home, and power buttons down simultaneously. Continue to hold this combination while your phone boots, or until the screen shows the iconic Android logo.
  5. Samsung Galaxy S6 Edge Plus Factory Reset, Good Bye: passo 5, immagine 1 di 1
    • After a few moments, you’ll have access to your phone’s boot menu. Using the volume buttons to navigate and the power button to make your selection, find and select Wipe Data/Factory Reset.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
luis fierro
Membro da: 04/30/18
373 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 4,035
