Introduzione
Use this guide to remove and replace the front camera lens from your phone.
Cosa ti serve
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
The front camera will be attached to the back of the motherboard.
Turn the motherboard around and use a plastic tool to undo the connection of the front camera.
