Salta al contenuto principale
Samsung Galaxy S5 microSD Card Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Samsung Galaxy S5 microSD Card Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy S5 microSD Card Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy S5 microSD Card Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
    • Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
  2. Samsung Galaxy S5 microSD Card Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S5 microSD Card Replacement: passo 2, immagine 2 di 2
    • Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
    • Remove the battery from the phone.
  3. Samsung Galaxy S5 microSD Card Replacement, microSD Card: passo 3, immagine 1 di 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: passo 3, immagine 2 di 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: passo 3, immagine 3 di 3
    • Gently slide out the SD card using your fingernail or a plastic opening tool.
    • For reassembly, gently slide in the microSD card until it stops.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 10-57, Amido Spring 2014 Membro di Cal Poly, Team 10-57, Amido Spring 2014
CPSU-AMIDO-S14S10G57
4 Membri
9 Guide realizzate
Un commento
Actually the battery does not even have to be removed (just unmount in settings first to avoid corruption)
Simply slide the card back until it runs into the battery, then just lift out.
BFeely - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,609
