Salta al contenuto principale
Samsung Galaxy S5 Sport Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy S5 Sport Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 2, immagine 3 di 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Motherboard Replacement, Screen: passo 3, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: passo 3, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Screen: passo 3, immagine 3 di 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Motherboard Replacement: passo 4, immagine 1 di 2 Samsung Galaxy S5 Sport Motherboard Replacement: passo 4, immagine 2 di 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: passo 5, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: passo 5, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Front-Facing Camera: passo 5, immagine 3 di 3
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Motherboard Replacement: passo 6, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 6, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 6, immagine 3 di 3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Motherboard Replacement: passo 7, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 7, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
  8. Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: passo 8, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: passo 8, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement, Motherboard: passo 8, immagine 3 di 3
  9. Samsung Galaxy S5 Sport Motherboard Replacement: passo 9, immagine 1 di 2 Samsung Galaxy S5 Sport Motherboard Replacement: passo 9, immagine 2 di 2
    • Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
  10. Samsung Galaxy S5 Sport Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Galaxy S5 Sport Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the black connector above the wires by pulling straight up with tweezers.
  11. Samsung Galaxy S5 Sport Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy S5 Sport Motherboard Replacement: passo 11, immagine 3 di 3
    • Pull the motherboard out. It should lift easily out of the phone.
Conclusione
USF Tampa, Team 1-6, Leahy Spring 2016 Membro di USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,547
