Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
This guide will show the user how to safely remove the battery from the phone. It is most likely the easiest replacement to accomplish. No tools are absolutely required. The battery is easily accessible through the back casing of the phone.
  1. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top.
    • Remove the back casing of the phone using the notch located at the top.
  2. Lift up the battery using a plastic spudger or fingernail. Damaging the battery may result in physical injury and/or damage to the phone. Damaging the battery may result in physical injury and/or damage to the phone.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
Conclusione
USF Tampa, Team 1-6, Leahy Spring 2016 Membro di USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 945
