Salta al contenuto principale
Samsung Galaxy S5 Mini SIM & SD card reader Replacement
Cosa ti serve
  1. Samsung Galaxy S5 Mini SIM & SD card reader Replacement, SIM & SD card reader: passo 1, immagine 1 di 1
    • Remove back cover.
  2. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 2, immagine 1 di 1
    • Remove battery. If you have SIM card and SD card in, remove them by the way.
  3. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 3, immagine 2 di 2
    • Open this cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, immagine 3 di 3
    • Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker.
  5. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 5, immagine 2 di 2
    • Remove the LCD screen from rear case.
  6. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 6, immagine 1 di 2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 6, immagine 2 di 2
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 7, immagine 1 di 2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 7, immagine 2 di 2
    • Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing.
  8. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 8, immagine 1 di 2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 8, immagine 2 di 2
    • Twist off these two screws and remove the whole motherboard assembly.
  9. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, immagine 1 di 3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, immagine 2 di 3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, immagine 3 di 3
    • Release the connector,loose the assembly from adhesive and remove it finally.
Conclusione
Altre 3 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,275
