Salta al contenuto principale
Samsung Galaxy S5 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, immagine 3 di 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Battery Replacement, Battery: passo 2, immagine 1 di 3 Samsung Galaxy S5 Battery Replacement, Battery: passo 2, immagine 2 di 3 Samsung Galaxy S5 Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Conclusione
Altre 83 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.602 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.724 Guide realizzate
10 Commenti
This is too complicated :(
Jaydon - Replica
Extremely easy
taesusman - Replica
I replaced the battery in my phone because it drained fast, and drained completely in any temp below 50, I put the new battery In but when I try to turn it on the farthest I get is the screen that says "Samsung galaxy s5" help?
mw - Replica
Do I also need to remove the sim card? Or can I just put a new battery in?
nancysapone - Replica
Thanks am replacing glass as well...easy to get the battery and sim out.
rob taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 208
Tutti i Tempi: 95,338
