Salta al contenuto principale
Samsung Galaxy S5 Active Front-Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy S5 Active Front-Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Rear Case: passo 1, immagine 3 di 3
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Active Front-Facing Camera Replacement, SIM Card: passo 2, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, SIM Card: passo 2, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, SIM Card: passo 2, immagine 3 di 3
    • Use your fingers to remove the SIM card
  3. Samsung Galaxy S5 Active Front-Facing Camera Replacement, Battery: passo 3, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Battery: passo 3, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Battery: passo 3, immagine 3 di 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
  4. Samsung Galaxy S5 Active Front-Facing Camera Replacement, Display: passo 4, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Display: passo 4, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Display: passo 4, immagine 3 di 3
    • Make sure the battery, the SIM card, and the MicroSD card have been removed. If these components are not removed, they may get damaged when the heat is applied.
    • In this step you'll be using a heat gun. The heat gun operates at high temperatures, and it may harm you or the device if not used appropriately. Please follow the heat gun safety procedures indicated in it's manual to prevent any harm.
    • Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
  5. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Starting from the upper left corner, insert a guitar pick in between the display and the phone case.
  6. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 6, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 6, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 6, immagine 3 di 3
    • Use the pick to pry the display by sliding the pick in the direction shown.
    • Make sure you pry the display around the edge of the phone. At the bottom of the screen there is a thin metallic strip that connects the display to the motherboard, and it can be easily damaged.
    • If any resistance is encountered, stop prying and reapply heat to continue prying.
  7. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 7, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 7, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 7, immagine 3 di 3
    • Use the pick to pry the sides and lower part of the display by sliding the pick through the phone.
  8. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 8, immagine 1 di 2 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 8, immagine 2 di 2
    • Using the guitar pick, lift the screen slightly.
    • You can remove the home button if desired.
  9. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 9, immagine 1 di 2 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 9, immagine 2 di 2
    • Slightly lift, but do not remove, the upper end of display assembly.
    • Do not remove the front panel entirely. It is still attached by a connector.
    • If you are reusing the home button flex cable, be careful not to sever the cable from the home button. Adhesive can cause the cable to rip apart from the home button. While the home button will still work, the fingerprint scanner will not.
  10. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 10, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 10, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 10, immagine 3 di 3
    • Use the sharp tip of a guitar pick to lift the front panel assembly cable connector straight up off its socket on the motherboard.
    • Safely remove the front panel assembly from phone.
  11. Samsung Galaxy S5 Active Front-Facing Camera Replacement, Front Camera: passo 11, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Front Camera: passo 11, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement, Front Camera: passo 11, immagine 3 di 3
    • Use a Phillips 0 screwdriver to remove all 11 Phillips #0 screws.
    • Make sure you don't lose them as they are small.
  12. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 12, immagine 1 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 12, immagine 2 di 3 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 12, immagine 3 di 3
    • Push upward from the back side your phone (where the battery should go) to pop out the large gray piece.
  13. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 13, immagine 1 di 1
    • You should now have two different pieces. To continue we will only use the piece with the motherboard (Shown on the right side of the picture).
  14. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 14, immagine 1 di 2 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 14, immagine 2 di 2
    • Use your finger or a plastic opening tool to disconnect the front-facing camera from the motherboard.
  15. Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 15, immagine 1 di 2 Samsung Galaxy S5 Active Front-Facing Camera Replacement: passo 15, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to gently pull the front-camera out.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 1-5, Hickman Fall 2014 Membro di USF Tampa, Team 1-5, Hickman Fall 2014
USFT-HICKMAN-F14S1G5
3 Membri
7 Guide realizzate
1Commento della guida
This is obviously not the front facing camera which is taken out in the end.
Those are the sensors. The camera is still in the upper right corner.
Same goes for the motherboard guide. Front camera is never disconnect nor taken out, this is an issue.
Nortontown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 65
Tutti i Tempi: 5,735
