Salta al contenuto principale
Samsung Galaxy S4 Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy S4 Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 2, immagine 3 di 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Motherboard Replacement, MicroSD Card: passo 3, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement, MicroSD Card: passo 3, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement, MicroSD Card: passo 3, immagine 3 di 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Galaxy S4 Motherboard Replacement, Battery: passo 4, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement, Battery: passo 4, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement, Battery: passo 4, immagine 3 di 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Motherboard Replacement, SIM Card: passo 5, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement, SIM Card: passo 5, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement, SIM Card: passo 5, immagine 3 di 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Samsung Galaxy S4 Motherboard Replacement, Midframe: passo 6, immagine 1 di 1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. Samsung Galaxy S4 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 7, immagine 2 di 2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clipsโ€”there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Samsung Galaxy S4 Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 8, immagine 2 di 2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Motherboard Replacement: passo 9, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 9, immagine 2 di 2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 10, immagine 2 di 2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  11. Samsung Galaxy S4 Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the midframe from the display assembly.
  12. Samsung Galaxy S4 Motherboard Replacement, Motherboard Assembly: passo 12, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement, Motherboard Assembly: passo 12, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement, Motherboard Assembly: passo 12, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
  13. Samsung Galaxy S4 Motherboard Replacement: passo 13, immagine 1 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 13, immagine 2 di 3 Samsung Galaxy S4 Motherboard Replacement: passo 13, immagine 3 di 3
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  14. Samsung Galaxy S4 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  15. Samsung Galaxy S4 Motherboard Replacement: passo 15, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 15, immagine 2 di 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  16. Samsung Galaxy S4 Motherboard Replacement, Motherboard: passo 16, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  17. Samsung Galaxy S4 Motherboard Replacement: passo 17, immagine 1 di 2 Samsung Galaxy S4 Motherboard Replacement: passo 17, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
Conclusione
Altre 159 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
467.161 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
30 Commenti
where can one buy a replacement motherboard?
Joe - Replica
I have a M919 with dead motherboard. Can i swap with an i9505motherboard insted? will all the components work on this new motherboard?
Augusto Nascimento - Replica
Hi I have a question. I have Galaxy S4 but The screen just broke and my sister give her galaxy s4 can i just change the motherboard to my phone or need to change the other parts too? Please help my i dont want to change all the parts if i dont need to!?
Ray Flores - Replica
Mboard only.
djweijers1997 -
i need S4 mother board too broher pls give me if you have extra i will pay
sukesh padinjarakkara -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 71
Tutti i Tempi: 197,554
