Salta al contenuto principale
Samsung Galaxy S4 Mini Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the back cover of the cell phone using a plastic opening tool.
    The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
    HÃ¥vard Haugen - Replica
  3. Samsung Galaxy S4 Mini Speaker Replacement: passo 3, immagine 1 di 1
    • Pry the battery out using a plastic opening tool.
    Vai s4 mini motherbotd paua jay
    atik.pgm - Replica
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: passo 4, immagine 1 di 2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: passo 4, immagine 2 di 2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: passo 5, immagine 1 di 1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, immagine 1 di 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, immagine 2 di 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, immagine 3 di 3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: passo 7, immagine 1 di 2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: passo 7, immagine 2 di 2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: passo 8, immagine 1 di 1
    • Insert the new loud speaker
Conclusione
Altre 31 persone hanno completato questa guida.
Luis Ojeda
Membro da: 09/23/14
989 Reputazione
1 Guida realizzata
USF Tampa, Team 9-2, Blackwell Fall 2014 Membro di USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Membri
11 Guide realizzate
3 Commenti
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Replica
loud & clear Thanks
Maarten Brenninkmeijer - Replica
perfect. thankyou
rick bailey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 13,753
