Introduzione
This motherboard replacement guide applies to the Verizon Samsung Galaxy S4 Mini, model number SCH-I435.
Cosa ti serve
Remove the back cover of the cell phone using a plastic opening tool.
The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
Does “slide it out” refer to memory card holder or the memory card itself?
Photo useless. Cannot see where “hole” is.
Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
Altre 3 persone hanno completato questa guida.
