Introduzione
Use this guide to replace your Samsung Galaxy S4 display assembly.
Cosa ti serve
Panoramica Video
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket.
Remove the upper display assembly bracket from the display.
Altre 597 persone hanno completato questa guida.
28 Commenti
HELP! step 28 just ends how do I insert the new one, how do I resemble the parts that used adhesives to stick?
Nearly all the guides end like this, you just need to work backwards through the steps using the new hardware.
Just work backwards like Nick stated. I usually reverse assemble the parts I take off so I know the order in which I need to put them back in.
Just run it along its track. Use a plastic spudger to push it down. Use 3m double sided adhesive tape to re-attach parts that require adhesive.
