Salta al contenuto principale
Samsung Galaxy S4 Active MicroSD Card Replacement
Cosa ti serve
  1. Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active MicroSD Card Replacement, MicroSD Card: passo 2, immagine 1 di 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
Conclusione
Altre 3 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
87.850 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,410
