Salta al contenuto principale
Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement
Cosa ti serve
  1. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 4, immagine 1 di 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 5, immagine 1 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 5, immagine 2 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 5, immagine 3 di 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 6, immagine 1 di 2 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement: passo 6, immagine 2 di 2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: passo 7, immagine 1 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: passo 7, immagine 2 di 3 Samsung Galaxy S Vibrant Unhooking Antenna Cable Replacement, Unhooking Antenna Cable: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
Conclusione
Cal Poly, Team 18-37, Regan Winter 2013 Membro di Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,169
