Salta al contenuto principale
Samsung Galaxy S Vibrant Battery Replacement
Cosa ti serve
  1. Samsung Galaxy S Vibrant Battery Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S Vibrant Battery Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
Conclusione
Cal Poly, Team 18-37, Regan Winter 2013 Membro di Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,601
