Salta al contenuto principale
Samsung Galaxy S Plus Front Panel Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy S Plus Front Panel Assembly Replacement, Front Panel Assembly: passo 1, immagine 1 di 2 Samsung Galaxy S Plus Front Panel Assembly Replacement, Front Panel Assembly: passo 1, immagine 2 di 2
    • Unscrew 7 screws on the rear using a Phillips screw driver.
  2. Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 2, immagine 1 di 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 2, immagine 2 di 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 2, immagine 3 di 3
    • Unhook the rear using a soft plastic prying tool to remove the rear cover
    • Be careful not to damage the rear cover when unhooking it.
  3. Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
  4. Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 4, immagine 1 di 1
    • Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnecting the camera connector isn't necessary!
  5. Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 5, immagine 1 di 1
    • After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • Make sure that the Power Key FPCB does not get stuck!
  6. Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 6, immagine 1 di 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 6, immagine 2 di 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: passo 6, immagine 3 di 3
    • Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
    • Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
    • Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
Conclusione
Altre 14 persone hanno completato questa guida.
Joao de Matos
Membro da: 07/02/13
383 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 8,733
