Introduzione
Use this guide to replace the front panel assembly, including the digitizer, speaker, and OK button on the Samsung Galaxy S Plus (i9001)
Cosa ti serve
Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
Altre 13 persone hanno completato questa guida.
