Introduzione
Use this guide to replace the microSD card.
Strumenti
Ricambi
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Altre 27 persone hanno completato questa guida.
