Salta al contenuto principale
Cosa ti serve
  1. Samsung Galaxy S III Motherboard Assembly Replacement, Motherboard Assembly: passo 1, immagine 1 di 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  2. Samsung Galaxy S III Motherboard Assembly Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S III Motherboard Assembly Replacement: passo 2, immagine 2 di 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  3. Samsung Galaxy S III Motherboard Assembly Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S III Motherboard Assembly Replacement: passo 3, immagine 2 di 2
    • Disconnect the display data cable from the motherboard.
  4. Samsung Galaxy S III Motherboard Assembly Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S III Motherboard Assembly Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S III Motherboard Assembly Replacement: passo 4, immagine 3 di 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  5. Samsung Galaxy S III Motherboard Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  6. Samsung Galaxy S III Motherboard Assembly Replacement: passo 6, immagine 1 di 2 Samsung Galaxy S III Motherboard Assembly Replacement: passo 6, immagine 2 di 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 136
