Salta al contenuto principale
Samsung Galaxy S II T989 Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: passo 1, immagine 1 di 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: passo 1, immagine 2 di 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: passo 1, immagine 3 di 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: passo 2, immagine 1 di 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: passo 2, immagine 2 di 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: passo 3, immagine 1 di 3 Samsung Galaxy S II T989 Speaker Replacement: passo 3, immagine 2 di 3 Samsung Galaxy S II T989 Speaker Replacement: passo 3, immagine 3 di 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: passo 4, immagine 1 di 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: passo 4, immagine 2 di 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
Conclusione
Altre 2 persone hanno completato questa guida.
Joshua King
Membro da: 03/26/14
1.378 Reputazione
9 Guide realizzate
Clemson, Team 1-5, Benson Spring 2014 Membro di Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Membri
9 Guide realizzate
3 Commenti
and one would purchase a speaker where?????? :-)
betty - Replica
speaker jumper ways
Muhammad azan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,490
