Salta al contenuto principale
Introduzione
This guide will show how to properly replace the SD card slot cover on a Samsung Galaxy S Blaze 4G. The replacement of the SD card slot cover is an easy process with no surprises. You will need to be careful while taking out the screws, the screws will damage easily.
Parti
Nessuna parte specificata.
  1. Remove the back plate to reveal the battery.
    • Remove the back plate to reveal the battery.
  2. Remove the battery from the device.
    • Remove the battery from the device.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Use a Phillips head screwdriver size 00. Remove the 4mm screws from the frame.
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  5. Use the blue plastic opening tool to pry the frame off the phone.
    • Use the blue plastic opening tool to pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  6. The SD cover is held in place on the frame by a small tab. Unhook the tab of the SD card slot cover from the frame of the device.
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
Conclusione
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
