Salta al contenuto principale
Samsung Galaxy S Blaze Power Button Replacement
Cosa ti serve
  1. Samsung Galaxy S Blaze Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone.
  2. Samsung Galaxy S Blaze Power Button Replacement: passo 2, immagine 1 di 1
    • Remove the battery, and use a small Phillips-head screwdriver to remove the marked up screws.
  3. Samsung Galaxy S Blaze Power Button Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S Blaze Power Button Replacement: passo 3, immagine 2 di 2
    • Use a flat tool to pry the two plastic cases apart.
    • The latches are very strong, so don't be afraid to use force.
  4. Samsung Galaxy S Blaze Power Button Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S Blaze Power Button Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S Blaze Power Button Replacement: passo 4, immagine 3 di 3
    • Locate the missing button slot.
    • Place in replacement button, and close the plastic housing around it.
    • The button should be fully functional now. Repeat past steps to reassemble the phone.
Conclusione
Un commento
Please can someone help me with samsung t769 power way on the board ?
Nyawu Ebenezer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,227
