Salta al contenuto principale
Samsung Galaxy S Blaze Display Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, immagine 1 di 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, immagine 2 di 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, immagine 3 di 3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone.
  2. Samsung Galaxy S Blaze Display Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the battery, and use a small Phillips-head screwdriver to remove the marked up screws.
  3. Samsung Galaxy S Blaze Display Assembly Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S Blaze Display Assembly Replacement: passo 3, immagine 2 di 2
    • Use a flat tool to pry the two plastic cases apart.
    • The latches are very strong, so don't be afraid to use force.
  4. Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, immagine 3 di 3
    • Locate the missing button slot.
    • Place in replacement button, and close the plastic housing around it.
    • The button should be fully functional now. Repeat past steps to reassemble the phone.
  5. Samsung Galaxy S Blaze Display Assembly Replacement, Display Assembly: passo 5, immagine 1 di 1
    • Gently remove the 2 ribbon cables as shown.
    • Connect the new screen to the main motherboard just the same way it was connected before.
    • Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,327
