Introduzione
This guide will help you replace the LCD screen or your motherboard on your Samsung Galaxy Rush. It is not a lengthy process and you will have a brand new screen in about 30 minutes.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Looking at the back of your phone, use your finger to remove back cover.
  • Looking at the back of your phone, use your finger to remove back cover.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
Aggiungi Commento
  • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
Aggiungi Commento
  • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
Aggiungi Commento
  • Using tweezers, gently lift connectors from motherboard.
  • A connector will be on the upper left
  • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
Aggiungi Commento
  • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
  • These stay attached to the motherboard so be careful not to break them.
  • They are on the side of the phone.
Aggiungi Commento
  • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
Aggiungi Commento
  • Lift the motherboard upwards separating it from your screen.
Aggiungi Commento
Conclusione
Kenny Afiadata
Membro da: 20/10/2014
36 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 466
