Salta al contenuto principale
Samsung Galaxy R Speaker Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy R Speaker Assembly Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: passo 1, immagine 3 di 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Speaker Assembly Replacement, Battery: passo 2, immagine 1 di 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: passo 2, immagine 2 di 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: passo 2, immagine 3 di 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Speaker Assembly Replacement, Remove screws: passo 3, immagine 1 di 2 Samsung Galaxy R Speaker Assembly Replacement, Remove screws: passo 3, immagine 2 di 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: passo 4, immagine 1 di 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: passo 4, immagine 2 di 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: passo 4, immagine 3 di 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Gently lift the bottom panel from the back of the phone.
  5. Samsung Galaxy R Speaker Assembly Replacement, Top Panel: passo 5, immagine 1 di 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: passo 5, immagine 2 di 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to grasp the vibrator piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Speaker Assembly Replacement, Speaker: passo 6, immagine 1 di 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: passo 6, immagine 2 di 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: passo 6, immagine 3 di 3
    • The speaker is located near the top of the phone underneath the motherboard circled in red.
    • To remove the speaker, gently pull on the strap attached until it releases from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 3-3, Benson Fall 2014 Membro di Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 572
