Salta al contenuto principale
Samsung Galaxy Prevail Rear Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: passo 1, immagine 1 di 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: passo 2, immagine 1 di 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: passo 4, immagine 1 di 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Prevail Rear Speaker Replacement: passo 5, immagine 2 di 2
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
Conclusione
USF Tampa, Team 17-6, Blackwell Fall 2016 Membro di USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 227
