Salta al contenuto principale
Samsung Galaxy Prevail 2 Vibrator Replacement
Cosa ti serve
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, immagine 3 di 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, immagine 3 di 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: passo 3, immagine 1 di 2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: passo 3, immagine 2 di 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, immagine 3 di 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, immagine 3 di 3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, immagine 3 di 3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, immagine 1 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, immagine 2 di 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, immagine 3 di 3
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: passo 8, immagine 1 di 1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 14-4, Leahy Fall 2014 Membro di USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,005
