Salta al contenuto principale
Samsung Galaxy Player 5.0 Screen Replacement
Cosa ti serve
  1. Samsung Galaxy Player 5.0 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the SD card before disassembling the device.
    • Use a screwdriver to remove the screw near the SD card.
  2. Samsung Galaxy Player 5.0 Screen Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Player 5.0 Screen Replacement: passo 2, immagine 2 di 2
    • Go to the bottom of the device and remove the white caps covering the screws.
    • If it is difficult to remove the white caps, use a heat blower to heat them before removing them.
    • After removing the caps, use a screwdriver to remove the screws at the bottom of the device. Set aside.
  3. Samsung Galaxy Player 5.0 Screen Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Player 5.0 Screen Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Player 5.0 Screen Replacement: passo 3, immagine 3 di 3
    • Starting from the bottom, use a pry tool to separate the front housing cover from the back cover.
    • Use a plastic prying tool if you can. Be extremely careful when separating the front housing cover.
    • Pull the front and back cover halves apart completely.
  4. Samsung Galaxy Player 5.0 Screen Replacement: passo 4, immagine 1 di 1
    • Use the pry tool to separate the tab connecting the battery and motherboard.
  5. Samsung Galaxy Player 5.0 Screen Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Use the prying tool to separate the battery from the motherboard.
    • Metal spudgers and similar pry tools can puncture an unprotected battery, potentially causing a fire. To be on the safe side, it’s better to use a plastic card or nylon spudger.
  6. Samsung Galaxy Player 5.0 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the ear piece using a pry tool. Set aside.
  7. Samsung Galaxy Player 5.0 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the front and rear cameras.
  8. Samsung Galaxy Player 5.0 Screen Replacement: passo 8, immagine 1 di 1
    • Disconnect the volume button from the motherboard.
    • It is not necessary to completely remove the volume buttons from the device after they have been disconnected.
  9. Samsung Galaxy Player 5.0 Screen Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Player 5.0 Screen Replacement: passo 9, immagine 2 di 2
    • Use a screwdriver to remove the screw pictured.
    • Use a prying tool to remove the headphone jack.
    • Set both carefully aside.
  10. Samsung Galaxy Player 5.0 Screen Replacement: passo 10, immagine 1 di 1
    • Disconnect the mean button flex cable.
    • Use a pry tool to open the locker on the motherboard and remove flex cable.
  11. Samsung Galaxy Player 5.0 Screen Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Player 5.0 Screen Replacement: passo 11, immagine 2 di 2
    • Disconnect the LCD flex cable.
    • Use a screwdriver to remove six screws pictured.
  12. Samsung Galaxy Player 5.0 Screen Replacement: passo 12, immagine 1 di 3 Samsung Galaxy Player 5.0 Screen Replacement: passo 12, immagine 2 di 3 Samsung Galaxy Player 5.0 Screen Replacement: passo 12, immagine 3 di 3
    • Hold the PCD unit and lift it up.
    • Switch out the old digitizer for the new one. Reconnect all the cables and screws in the reverse sequence.
Conclusione
Wenbin Weng
Membro da: 01/28/17
122 Reputazione
1 Guida realizzata
IUPUI, Team S4-G4, Wilson Spring 2017 Membro di IUPUI, Team S4-G4, Wilson Spring 2017
IUPUI-WILSON-S17S4G4
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 678
