Salta al contenuto principale
Samsung Galaxy On5 Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy On5 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the side notch that allows you to open the back casing.
  2. Samsung Galaxy On5 Speaker Replacement: passo 2, immagine 1 di 3 Samsung Galaxy On5 Speaker Replacement: passo 2, immagine 2 di 3 Samsung Galaxy On5 Speaker Replacement: passo 2, immagine 3 di 3
    • Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
  3. Samsung Galaxy On5 Speaker Replacement: passo 3, immagine 1 di 3 Samsung Galaxy On5 Speaker Replacement: passo 3, immagine 2 di 3 Samsung Galaxy On5 Speaker Replacement: passo 3, immagine 3 di 3
    • Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
    • Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
  4. Samsung Galaxy On5 Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Samsung Galaxy On5 Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Before disassembling the phone, take out the SIM card and microSD card.
    • Use a plastic pry tool to slide both of the cards out.
    • Do not use a metal pry tool. Using this could cause damage to the cards and/or card holder.
  5. Samsung Galaxy On5 Speaker Replacement: passo 5, immagine 1 di 3 Samsung Galaxy On5 Speaker Replacement: passo 5, immagine 2 di 3 Samsung Galaxy On5 Speaker Replacement: passo 5, immagine 3 di 3
    • Use the plastic Spudger tool to pry open the LCD ribbon cable cover.
    • This part might be a little hard to open. Take your time and be careful not to push too hard as doing so could result in damage to the ribbon.
  6. Samsung Galaxy On5 Speaker Replacement: passo 6, immagine 1 di 3 Samsung Galaxy On5 Speaker Replacement: passo 6, immagine 2 di 3 Samsung Galaxy On5 Speaker Replacement: passo 6, immagine 3 di 3
    • Using a plastic pry tool, carefully pry the LCD ribbon cable from the logic board.
    • Do not use a metal pry tool. Metal pry tools can cause damage to the logic board and to the ribbon cable.
    • This LCD ribbon cable sends signal from the logic board to the LCD screen.
  7. Samsung Galaxy On5 Speaker Replacement: passo 7, immagine 1 di 2 Samsung Galaxy On5 Speaker Replacement: passo 7, immagine 2 di 2
    • Take a Phillips #00 head and remove all 9 screws. Once done place them aside where you won't lose them.
    • All 9 screws are the same size.
  8. Samsung Galaxy On5 Speaker Replacement: passo 8, immagine 1 di 2 Samsung Galaxy On5 Speaker Replacement: passo 8, immagine 2 di 2
    • Use an iFixit plastic pick to pry away the LCD from the back assembly.
    • This process will take some time due to the glue that's holding the LCD and back assembly together. Slowly move around the edge of the screen to loosen the glue up.
    • If you have a heat gun, you can use it to heat up the glue. Heating up the glue makes it easier to separate the LCD and back assembly.
  9. Samsung Galaxy On5 Speaker Replacement: passo 9, immagine 1 di 3 Samsung Galaxy On5 Speaker Replacement: passo 9, immagine 2 di 3 Samsung Galaxy On5 Speaker Replacement: passo 9, immagine 3 di 3
    • Once both the LCD and back assembly come apart, look at the back assembly where the speaker is located.
    • Once located, take the plastic pry tool to remove the speaker from its housing and replace it with a new one.
Conclusione
Altre 3 persone hanno completato questa guida.
Gateway, Team S1-G5, Luster Fall 2018 Membro di Gateway, Team S1-G5, Luster Fall 2018
GCC-LUSTER-F18S1G5
1 Membro
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,045
