Introduzione
If your Galaxy Note9 battery drains quickly, won’t charge, or won’t power on it may be time for a replacement. Follow this guide to install a fresh battery.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your phone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Cosa ti serve
Power off your phone before beginning disassembly.
Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
Apply a suction handle to the back cover.
Lift with a suction handle to create a gap between the back cover and the frame of the phone.
Insert an opening pick into the gap.
Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
Starting from the center, cut the adhesive up and down the right side with an opening pick.
Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
Turn on your phone and test your repair before installing new adhesive and resealing the phone.
Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
Passo 12 Remove the upper midframe
Attenzione: i passaggi 12-15 provengono da una guida contrassegnata come in corso.
Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
Apply a few drops of 90% isopropyl alcohol in the battery well along the bottom and in the upper-left corner of the battery.
Wait a couple of minutes for the alcohol to soften the adhesive under the battery.
Tilt the phone at various angles to help the alcohol flow under the battery.
Altre 48 persone hanno completato questa guida.
7 Commenti
Great guide, much thanks!
شكرا لك اليوم. لقد استبدلت البطارية بسهولة باتباع الخطوات الأولى في المرحلة الأولى. شكرا
Thanks very much for posting this - it helped a lot. My Note 9 lives on!
Robert Oswald 4/29/21
Great to hear Robert, and good job!
