Salta al contenuto principale
Samsung Galaxy Note5 Volume Button Replacement
Cosa ti serve
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: passo 1, immagine 1 di 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: passo 2, immagine 1 di 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: passo 3, immagine 1 di 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: passo 4, immagine 1 di 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: passo 5, immagine 1 di 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: passo 6, immagine 1 di 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: passo 7, immagine 1 di 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: passo 8, immagine 1 di 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Note5 Volume Button Replacement: passo 9, immagine 2 di 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Note5 Volume Button Replacement: passo 10, immagine 2 di 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Note5 Volume Button Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: passo 12, immagine 1 di 1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: passo 13, immagine 1 di 2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: passo 13, immagine 2 di 2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: passo 14, immagine 1 di 1
    • Push out the volume button and remove it from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Bernice Nunez
Membro da: 04/19/18
361 Reputazione
2 Guide realizzate
Cal Poly, Team S25-G17, Maness Spring 2018 Membro di Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,429
