Salta al contenuto principale
Samsung Galaxy Note5 Display Replacement
Cosa ti serve
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: passo 1, immagine 1 di 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: passo 2, immagine 1 di 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: passo 3, immagine 1 di 1
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: passo 4, immagine 1 di 1
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Display Replacement: passo 5, immagine 1 di 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: passo 6, immagine 1 di 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: passo 7, immagine 1 di 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: passo 8, immagine 1 di 1
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Note5 Display Replacement: passo 9, immagine 2 di 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Display Replacement: passo 10, immagine 1 di 3 Samsung Galaxy Note5 Display Replacement: passo 10, immagine 2 di 3 Samsung Galaxy Note5 Display Replacement: passo 10, immagine 3 di 3
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: passo 11, immagine 1 di 1
    • Loosen the two signal cable connectors.
  12. Samsung Galaxy Note5 Display Replacement: passo 12, immagine 1 di 3 Samsung Galaxy Note5 Display Replacement: passo 12, immagine 2 di 3 Samsung Galaxy Note5 Display Replacement: passo 12, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
  13. Samsung Galaxy Note5 Display Replacement: passo 13, immagine 1 di 1
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: passo 14, immagine 1 di 1
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: passo 15, immagine 1 di 3 Samsung Galaxy Note5 Display Replacement: passo 15, immagine 2 di 3 Samsung Galaxy Note5 Display Replacement: passo 15, immagine 3 di 3
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
  16. Samsung Galaxy Note5 Display Replacement: passo 16, immagine 1 di 1
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: passo 17, immagine 1 di 1
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: passo 18, immagine 1 di 1
    • The display is now removed.
Conclusione
Altre 41 persone hanno completato questa guida.
Cal Poly, Team S25-G17, Maness Spring 2018 Membro di Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Membri
6 Guide realizzate
6Commenti sulla guida
Worked like a charm
Ronald Sapp - Replica
How does one bond everything back together?
lcplthomasc - Replica
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 101
Tutti i Tempi: 26,193
