Salta al contenuto principale
Samsung Galaxy Note Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Note Motherboard Replacement, Stylus: passo 1, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, Stylus: passo 1, immagine 2 di 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Motherboard Replacement, Rear Case: passo 2, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, Rear Case: passo 2, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 3, immagine 2 di 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Motherboard Replacement, Battery: passo 4, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Motherboard Replacement, MicroSD Card: passo 5, immagine 1 di 3 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: passo 5, immagine 2 di 3 Samsung Galaxy Note Motherboard Replacement, MicroSD Card: passo 5, immagine 3 di 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Motherboard Replacement, SIM Card: passo 7, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, SIM Card: passo 7, immagine 2 di 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 8, immagine 2 di 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Motherboard Replacement, Midframe: passo 9, immagine 1 di 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 10, immagine 2 di 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Note Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Note Motherboard Replacement: passo 11, immagine 3 di 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Motherboard Replacement: passo 12, immagine 1 di 3 Samsung Galaxy Note Motherboard Replacement: passo 12, immagine 2 di 3 Samsung Galaxy Note Motherboard Replacement: passo 12, immagine 3 di 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Motherboard Replacement: passo 13, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: passo 14, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, Motherboard Assembly: passo 14, immagine 2 di 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Motherboard Replacement: passo 15, immagine 1 di 3 Samsung Galaxy Note Motherboard Replacement: passo 15, immagine 2 di 3 Samsung Galaxy Note Motherboard Replacement: passo 15, immagine 3 di 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Motherboard Replacement: passo 16, immagine 1 di 3 Samsung Galaxy Note Motherboard Replacement: passo 16, immagine 2 di 3 Samsung Galaxy Note Motherboard Replacement: passo 16, immagine 3 di 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Motherboard Replacement: passo 18, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 18, immagine 2 di 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: passo 19, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement, Rear Facing Camera: passo 19, immagine 2 di 2
    • Use a plastic opening tool to flip the release tab on the rear-facing camera cable ZIF connector.
    • Only pry on the tab, not the connector itself.
  20. Samsung Galaxy Note Motherboard Replacement: passo 20, immagine 1 di 2 Samsung Galaxy Note Motherboard Replacement: passo 20, immagine 2 di 2
    • Slide the tip of a spudger under the rear-facing camera cable to slide it out of the ZIF connector and free it from the light adhesive.
  21. Samsung Galaxy Note Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove the rear-facing camera.
Conclusione
Altre 20 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.970 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.299 Guide realizzate
4 Commenti
from where I can get the motherboard for Samsung Galaxy note 3???
abdom911 - Replica
Can You Assist Me where can I purchase samsung GT- N7000 mother board. GALAXY NOTE 1
edcas2158 - Replica
i need note 7000 motherboard
rajeev kapoor - Replica
How much does it cost for buying a Samsung Galaxy Note4 motherboard ? And where will I get it in Bangalore
LIGHT BREEZE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 36,748
