Salta al contenuto principale
Samsung Galaxy Note Midframe Replacement
Cosa ti serve
  1. Samsung Galaxy Note Midframe Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  2. Samsung Galaxy Note Midframe Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement: passo 2, immagine 2 di 2
    • Lift and remove the rear case from the phone.
  3. Samsung Galaxy Note Midframe Replacement, Battery: passo 3, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement, Battery: passo 3, immagine 2 di 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  4. Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, immagine 1 di 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, immagine 2 di 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, immagine 3 di 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note Midframe Replacement: passo 5, immagine 1 di 1
    • Remove the microSD card from its slot in the midframe.
  6. Samsung Galaxy Note Midframe Replacement, SIM Card: passo 6, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement, SIM Card: passo 6, immagine 2 di 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  7. Samsung Galaxy Note Midframe Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement: passo 7, immagine 2 di 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  8. Samsung Galaxy Note Midframe Replacement, Midframe: passo 8, immagine 1 di 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  9. Samsung Galaxy Note Midframe Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement: passo 9, immagine 2 di 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  10. Samsung Galaxy Note Midframe Replacement: passo 10, immagine 1 di 3 Samsung Galaxy Note Midframe Replacement: passo 10, immagine 2 di 3 Samsung Galaxy Note Midframe Replacement: passo 10, immagine 3 di 3
    • Slide the plastic opening tool down the seam.
  11. Samsung Galaxy Note Midframe Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Note Midframe Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Note Midframe Replacement: passo 11, immagine 3 di 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  12. Samsung Galaxy Note Midframe Replacement: passo 12, immagine 1 di 2 Samsung Galaxy Note Midframe Replacement: passo 12, immagine 2 di 2
    • Remove the midframe from the display assembly.
Conclusione
Altre 16 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
474.924 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 11,043
