Salta al contenuto principale
Samsung Galaxy Note Midframe Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Samsung Galaxy Note Midframe Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Note Midframe Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Note Midframe Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Midframe Replacement: passo 2, immagine 1 di 1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Midframe Replacement: passo 3, immagine 1 di 1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Midframe Replacement, Midframe: passo 4, immagine 1 di 1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Midframe Replacement: passo 5, immagine 1 di 1
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Midframe Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Note Midframe Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Note Midframe Replacement: passo 6, immagine 3 di 3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
Conclusione
Altre 4 persone hanno completato questa guida.
David Ritter
Membro da: 04/14/13
758 Reputazione
6 Guide realizzate
Cal Poly, Team 3-45, Amido Spring 2013 Membro di Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,000
