Salta al contenuto principale
Samsung Galaxy Note II Speaker Enclosure Replacement
Cosa ti serve
  1. Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: passo 1, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: passo 1, immagine 2 di 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: passo 2, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: passo 2, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, immagine 3 di 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, immagine 1 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, immagine 2 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, immagine 3 di 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: passo 5, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: passo 5, immagine 2 di 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Speaker Enclosure Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, immagine 3 di 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, immagine 3 di 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 10, immagine 2 di 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 11, immagine 2 di 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 12, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 12, immagine 2 di 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 13, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 13, immagine 2 di 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 14, immagine 1 di 2 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 14, immagine 2 di 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Speaker Enclosure Replacement, Speaker Enclosure: passo 15, immagine 1 di 1
    • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
  16. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 16, immagine 1 di 1
    • Remove the speaker enclosure.
Conclusione
Altre 9 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
467.548 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.074 Guide realizzate
Un commento
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 13,849
