Introduzione
The Power Button and Ear Speaker of the phone are part of one component, and thus must be replaced together. The Power Button is responsible for turning the phone on/off, as well as resetting the phone. The speaker is responsible for sound during phone calls.
Cosa ti serve
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
Remove the stylus from the stylus holder.
Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
Insert your spudger into the stylus socket and pry the midframe from the phone.
Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
Gently insert the pointed end of your spudger under the gold ribbon connecting the speaker and power button.
Lift the ribbon to disconnect it from the frame.
