Salta al contenuto principale
Samsung Galaxy Note 8.0 Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Note 8.0 Speaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Speaker Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Speaker Replacement: passo 3, immagine 1 di 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Speaker Replacement, Battery: passo 4, immagine 1 di 2 Samsung Galaxy Note 8.0 Speaker Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Speaker Replacement: passo 5, immagine 1 di 1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Speaker Replacement: passo 6, immagine 1 di 1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: passo 7, immagine 1 di 3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: passo 7, immagine 2 di 3 Samsung Galaxy Note 8.0 Speaker Replacement, Speakers: passo 7, immagine 3 di 3
    • Gently pry up the connectors there is one per speaker
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  8. Samsung Galaxy Note 8.0 Speaker Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Note 8.0 Speaker Replacement: passo 8, immagine 2 di 2
    • For each speaker remove the two 3-mm Phillips head screws using a Phillips #00 screwdriver.
  9. Samsung Galaxy Note 8.0 Speaker Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Note 8.0 Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the speakers from their housing.
    • If difficult use a plastic opening tool to pry up.
Conclusione
Altre 4 persone hanno completato questa guida.
Joel
Membro da: 09/23/14
1.862 Reputazione
6 Guide realizzate
USF Tampa, Team 12-2, Blackwell Fall 2014 Membro di USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,735
