Introduzione
The headphone jack is the port you connect your headphone to in order to receive the sound from the tablet through headphones. Over time, the headphone jack or the terminal connections can become worn out or damaged, which may result in headphones not receiving sound properly. In this case, the headphone jack has to be replaced and this guide will show you how.
Strumenti
Ricambi
Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
Altre 6 persone hanno completato questa guida.
