Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The era of curved screen has arrived since the release of Samsung S6 Edge. After years of development, a brand new curved full screen has been adopted, which comes as a combination of curved screens and full screens. Compared with curved screens, the new curved full screen undoubtedly bears a much higher repair/refurbish cost. In our video today, we will take Samsung Galaxy Note 8 as an example and show you the latest curved full screen refurbishing technology.
Panoramica Video
  1. Place the phone upside down on the Heat Platform, remove the back cover slowly with Pry Piece and Glue Cleaner.
    • Place the phone upside down on the Heat Platform, remove the back cover slowly with Pry Piece and Glue Cleaner.
    • Continue to discharge the rear plate. Take out the battery and some other accessories, then take out the motherboard.
  2. Put the OLED screen assembly into the -180℃ Frozen Screen Separator. Then get the lid on and wait for 5 minutes and remove the glass lens carefully.
    • Put the OLED screen assembly into the -180℃ Frozen Screen Separator. Then get the lid on and wait for 5 minutes and remove the glass lens carefully.
    • Next, place the room temperature OLED screen on the Heat Platform, and remove residual glue with the Electric Glue Removing Device. Once done, clean with N-hexane.
  3. Put the OLED screen into the -180℃ Frozen Screen Separator, get the lid on and wait for 5 minutes. And then separate the OLED screen from the mid-frame.
    • Put the OLED screen into the -180℃ Frozen Screen Separator, get the lid on and wait for 5 minutes. And then separate the OLED screen from the mid-frame.
  4. The OCA should be laminated to the glass lens at first.
    • The OCA should be laminated to the glass lens at first.
    • Place the mold into the laminating machine, press ‘OCA lamination’ button and the machine starts to work.
    • Next, take out the OCA attached glass lens.
  5. Put the OCA attached glass lens into Bubble Removing Machine for 5 minutes. Once finished, take out the OCA attached glass lens.
    • Put the OCA attached glass lens into Bubble Removing Machine for 5 minutes. Once finished, take out the OCA attached glass lens.
  6. Now we need to laminate the OCA attached glass lens to the OLED screen.
    • Now we need to laminate the OCA attached glass lens to the OLED screen.
    • Place the mold into the laminating machine, press ‘LCD lamination’ button.
    • Once finished, take out the OLED screen assembly.
  7. Put the OLED screen assembly into Bubble Removing Machine for 10 minutes. Once finished, take out the OLED screen assembly.
    • Put the OLED screen assembly into Bubble Removing Machine for 10 minutes. Once finished, take out the OLED screen assembly.
  8. Power on to run function test – Display & Touch. All going well.
    • Power on to run function test – Display & Touch. All going well.
Phryne
Membro da: 17/11/2019
10.421 Reputazione
80 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 311
Tutti i Tempi: 1,102
