Salta al contenuto principale
Samsung Galaxy Note 4 Antenna Replacement
Cosa ti serve
  1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: passo 1, immagine 1 di 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Samsung Galaxy Note 4 Antenna Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Note 4 Antenna Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Note 4 Antenna Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Samsung Galaxy Note 4 Antenna Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Samsung Galaxy Note 4 Antenna Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Note 4 Antenna Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Note 4 Antenna Replacement: passo 4, immagine 3 di 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: passo 5, immagine 1 di 2 Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
Conclusione
Altre 19 persone hanno completato questa guida.
Derek Nola
Membro da: 01/06/15
2.244 Reputazione
5 Guide realizzate
Cal Poly, Team 70-6, Forte Winter 2015 Membro di Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
4 Membri
16 Guide realizzate
6 Commenti
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - Replica
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - Replica
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - Replica
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 23,347
