Salta al contenuto principale
Samsung Galaxy Note 3 Headphone Jack Replacement
Cosa ti serve
  1. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove the rear case: passo 1, immagine 1 di 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: passo 2, immagine 1 di 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Case from the Base: passo 2, immagine 2 di 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: passo 3, immagine 1 di 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Battery: passo 3, immagine 2 di 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Headphone Jack Replacement, S Pen: passo 4, immagine 1 di 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Headphone Jack Replacement, Unscrew Back Chassis: passo 5, immagine 1 di 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Headphone Jack Replacement, Remove Back Chassis: passo 6, immagine 1 di 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: passo 7, immagine 1 di 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Screw Removal: passo 7, immagine 2 di 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: passo 8, immagine 1 di 2 Samsung Galaxy Note 3 Headphone Jack Replacement, Unfasten Clips and Cable Connectors: passo 8, immagine 2 di 2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Headphone Jack Replacement, Motherboard Removal: passo 9, immagine 1 di 1
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Headphone Jack Replacement, Spudger Tool Placement: passo 10, immagine 1 di 1
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Headphone Jack Replacement, Lift to Separate Headphone Jack: passo 11, immagine 1 di 1
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
Conclusione
Altre 23 persone hanno completato questa guida.
Brittany Gail
Membro da: 09/23/14
8.486 Reputazione
8 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro di USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 14,964
