Strumenti
This is the back of the device and where you will begin to take it apart
It is neccesary to remove this piece first before removing the bigger back piece.
Use the plastic opening tools to pry along the indicated box.
Lift up the silver piece to reveal the rest of the back cover.
Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
Remove the back cover.
Carefully remove all of the ribbons that connect over the battery from the locations indicated by the yellow circles.
Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
Disconnect the battery from the location indicated by a yellow circle
Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
Altre 44 persone hanno completato questa guida.
12 Commenti
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
Actually, on my device one lock was colored faun (beige). Lift them seen from the edge of the Note, not on the cable side.
dada64 -
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
This is not a plug to be pulled in the direction of the cables but vertically off the board. Putting it back in you simply plug the contacts down first, then the cable side of the plug.
dada64 -
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
