Salta al contenuto principale
Samsung Galaxy Note 10.1 2014 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: passo 1, immagine 1 di 2 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $2.99
    Compra
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Battery Replacement: passo 3, immagine 1 di 1
    Phillips #000 Screwdriver
    $5.49
    Compra
  4. Samsung Galaxy Note 10.1 2014 Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Note 10.1 2014 Battery Replacement: passo 4, immagine 2 di 2
    Spudger
    $2.99
    Compra
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
Conclusione
Altre 27 persone hanno completato questa guida.
Joseph Rasico
Membro da: 02/20/17
2.200 Reputazione
6 Guide realizzate
USF Tampa, Team S1-G6, Leahy Spring 2017 Membro di USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Membri
6 Guide realizzate
5 Commenti
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - Replica
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - Replica
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols -
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - Replica
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 123
Tutti i Tempi: 22,030
