Salta al contenuto principale
Samsung Galaxy Nexus Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Nexus Motherboard Replacement, Back of Phone: passo 1, immagine 1 di 1
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: passo 2, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: passo 2, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: passo 2, immagine 3 di 3
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: passo 3, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: passo 3, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: passo 3, immagine 3 di 3
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Samsung Galaxy Nexus Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
    The screws need to be labeled with the head type and the length.
    Spencer - Replica
    Confusing heading.
    Dan Brown - Replica
    This is something that cannot be fixed. Due to it being a prerequisite guide it comes up with the title of the guide itself as it is inserted as a prerequisite guide.
    Stephan Williams -
  5. Samsung Galaxy Nexus Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 5, immagine 3 di 3
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
  6. Samsung Galaxy Nexus Motherboard Replacement, Removing Control Board: passo 6, immagine 1 di 2 Samsung Galaxy Nexus Motherboard Replacement, Removing Control Board: passo 6, immagine 2 di 2
    • Unscrew 4.4mm with a PH #000 marked screw.
    Add head type for screw.
    Dan Brown - Replica
  7. Samsung Galaxy Nexus Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Nexus Motherboard Replacement: passo 7, immagine 2 di 2
    • With the flat head screw driver pull up the blue connector.
    flat-head? flat head?
    Dan Brown - Replica
    Great pictures!
    Dan Brown - Replica
    Don't omit articles.
    Dan Brown - Replica
  8. Samsung Galaxy Nexus Motherboard Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 8, immagine 3 di 3
    • With you finger or prying tool pull back bottom module.
    You should add a step to pry off the connection on the side of the board also.
    Spencer - Replica
    Change "pulled back" to "pull back."
    Dan Brown - Replica
  9. Samsung Galaxy Nexus Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
  10. Samsung Galaxy Nexus Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Nexus Motherboard Replacement: passo 10, immagine 2 di 2
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
    There are 2 tabs that need to be disconnected, not just one.
    Spencer - Replica
  11. Samsung Galaxy Nexus Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the antenna using either your fingers or tweezers.
  12. Samsung Galaxy Nexus Motherboard Replacement: passo 12, immagine 1 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 12, immagine 2 di 3 Samsung Galaxy Nexus Motherboard Replacement: passo 12, immagine 3 di 3
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
    Last photo is blurry.
    Dan Brown - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
I believe the blue tool needs to be called the "plastic opening tool."
Dan Brown - Replica
were i can find mother board i need the mother board
bangera.kaushik990 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,068
