Salta al contenuto principale
Samsung Galaxy Mega Speaker Assmebly Replacement
Cosa ti serve
  1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement: passo 2, immagine 3 di 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, immagine 1 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, immagine 2 di 3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: passo 3, immagine 3 di 3
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
Conclusione
nithin
Membro da: 02/04/16
137 Reputazione
1 Guida realizzata
USF Tampa, Team 17-2, Blackwell Winter 2016 Membro di USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 846
