Salta al contenuto principale
Samsung Galaxy Mega Midframe Replacement
Cosa ti serve
  1. Samsung Galaxy Mega Midframe Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Mega Midframe Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Mega Midframe Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Midframe Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Mega Midframe Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Mega Midframe Replacement: passo 2, immagine 3 di 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Midframe Replacement, Midframe: passo 3, immagine 1 di 3 Samsung Galaxy Mega Midframe Replacement, Midframe: passo 3, immagine 2 di 3 Samsung Galaxy Mega Midframe Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Midframe Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Mega Midframe Replacement: passo 4, immagine 2 di 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
Conclusione
Altre 5 persone hanno completato questa guida.
Aaron Fulton
Membro da: 02/04/16
1.246 Reputazione
3 Guide realizzate
USF Tampa, Team 17-2, Blackwell Winter 2016 Membro di USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,146
