Salta al contenuto principale
Samsung Galaxy Mega 2 Rear Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Mega 2 Rear Camera Replacement, Rear Camera: passo 1, immagine 1 di 1
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Rear Camera Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 2, immagine 2 di 2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Rear Camera Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 3, immagine 3 di 3
    • Use phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use pry tool to disconnect the digitizer.
  4. Samsung Galaxy Mega 2 Rear Camera Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 4, immagine 3 di 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off to completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
  5. Samsung Galaxy Mega 2 Rear Camera Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Mega 2 Rear Camera Replacement: passo 5, immagine 3 di 3
    • Once the rear assembly frame is removed you will see the motherboard and the connectors.
    • Locate the rear facing camera in the top middle of the phone.
    • Using tweezers lift up on the motherboard itself to disconnect it from the mid-frame.
    • Flip the motherboard over.
    • Use the tweezers to then disconnect the rear facing camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 713
