Salta al contenuto principale
Samsung Galaxy Mega 2 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Mega 2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before begining, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once you get the corner released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Mega 2 Battery Replacement: passo 2, immagine 2 di 2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
    • Remove the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,565
